Projects window
When P6 Professional is connected to a P6 Professional database, use the Projects window to set up the EPS (Enterprise Project Structure), add new projects, and manage multiple projects.
When P6 Professional is connected to a P6 EPPM database, use the Projects window to work with the EPS (Enterprise Project Structure), add new projects, and manage multiple projects.
You can divide the Projects window into top and bottom layout views, and you can customize these layouts and how projects are displayed.
To display the Projects window, do one of the following:
Refer to the following sections of this topic for information and links to concepts and tasks about working with projects in the Projects window:
Working in the Projects window:
When working in the Projects window, you can:
Notes
When connected to a P6 EPPM database: The following applies when you filter by a unit or duration field (associated with activity data) from the Projects window: If the Use the assigned calendar to specify the number of work hours for each time period checkbox is cleared (Application Settings in P6), then filtering applies the unit or duration value based on the Application Settings in P6 hours per time period settings.
If the checkbox is marked, then filtering applies the unit or duration values as follows: For open projects, duration or unit values use the project calendar. For closed projects, duration and unit values use the global default calendar.
When connected to a P6 EPPM database: For open projects, values in unit and duration fields are calculated using the project calendar if the settings made from the P6 Application Settings specify to use calendar hours per time period settings to calculate units and durations.
When connected to a P6 EPPM database: For closed projects, values in unit and duration fields are calculated using the Application Settings in P6 hours per time period settings if the project's calendar is not a global calendar, even if the Application Settings in P6 specify to use calendar hours per time period settings to calculate units and durations.
Tips
Project concepts
The following topics describe project-related concepts. These concepts apply to data you define for projects (for example, activities or WBS elements), data you assign to activities (for project codes), and data or features that impact project data (for example, scheduling projects). These concepts do not necessarily apply to the Projects window, but they do apply to projects in general.
Project tasks
You can perform all of the following tasks in the Projects window. These tasks do not include project-related tasks that you can perform outside of the Projects window, such as assigning baselines to projects and scheduling projects.
Related Topics
Project Toolbar
Menu bar
Edit Toolbar
Top Layout Toolbar
Layout Toolbar
Project Details
Bottom Layout Toolbar
Change the current portfolio
Activities
Baselines
Calendars
Defining project details
Earned Value
Establishing budgets
Enterprise Project Structure overview
Expenses
Issues
Managing projects using the EPS
Managing remote projects
Portfolios
Project codes and values
Projects
Rolling up data with the summary service
Risks (P6 Professional Only)
Scheduling projects
Store Period Performance
Updating progress
Thresholds
Updating the schedule
Using Reflection projects and Activity Owner features to collect and review activity status (P6 EPPM Only)
Viewing summary project information
Work Breakdown Structure
Work Products and Documents
Add a project to the EPS hierarchy
Change a project ID
Assign project codes and values
Assign funding sources
Change the data date
Change a project's status
Change a project name
Change the project leveling priority
Close a project
Compare budgets and variances
Copy and paste a project
Copy an EPS node or project
Create a project
Create a Reflection
Define a what-if project
Enter project dates
Enter monthly spending amounts
Enter budget changes
Delete an EPS node or project
Delete a project
Printing a reflection difference report
Open a project
Merging a Reflection with the Source project
Establish budgets
Set the default rate type for resource assignments
Set the default price for activities
Set project resource options
Set activity ID options
Set a project's summarization options
Set the project default activity type
Set the project default activity percent complete type
Set the project default activity duration type
Set the project default activity calendar
Set the float time for identifying critical activities
View the check-out status of a project
View budget and spending plan totals
Summarize project data
Specify a fiscal start month
Set the project default cost account
Last Published Wednesday, March 5, 2025
