Applying Filters
Projects > Activities > About Activity Views > Configuring Activity Views > Configuring Activity View Filters
Apply filters to a project to specify the data you want to display. You can add user-created filters or select from the list of standard filters.
To apply filters:
- Click Projects.
- On the Projects navigation bar, click Activities or EPS.
- On the Activities or EPS page:
- Click the Views list and select a view to which you will add the filters.
- Click Customize View.
- In the Customize View dialog box, click the Filtering tab.
- On the Filtering tab:
- Select to match all applied or any applied.
- In the filter list, select the option for each filter you want to apply.
- Click Save and Apply.
Tips
- If you have Contributor module access, either assigned as a resource or activity owner, applying the My Activities filter will have no affect on the activity list display because your access is already restricted to your assigned and owner activities.
- You can also click the View menu and select Filters from the Filters submenu to open the Customize Filters dialog box. You can apply filters from this dialog box.
- If you want to save the application of these filters to the view, click Yes in the Primavera P6 dialog box which opens when you navigate away from the page.
Related Topics
Last Published Wednesday, July 10, 2024
