Configuring Filters
Projects > Activities > About Activity Views > Configuring Activity Views > Configuring Activity View Filters
You can configure the detailed statements of a filter and who can use it.
To configure filters:
- Click Projects.
- On the Projects navigation bar, click Activities or EPS.
- On the Activities or EPS page:
- Click the Views list and select a view to which you will add the filters.
- Click Filters and select Manage Filters....
- In the Manage Filters dialog box:
- To add a new filter, click Row Actions and select Add.
- Select a filter and configure the fields and lists to edit the filter statements.
- Click Save.
Tips
- You can not edit Standard Filters.
- To add more filter statements to the Definition tab, click
. To remove a filter, click
. To nest a criteria statement inside another, click
. You can add up to ten levels of nesting. - You can also click the View menu and select Filters from the Filters submenu to open the Customize Filters dialog box. You can configure filters from this dialog box.
Related Topics
Last Published Wednesday, July 10, 2024
