Administrators use the Actions Mapping tab to map Non-Status Changing Case Actions to user roles, and case statuses. Mapping actions in this way allows you to restrict which actions are available for users to move cases through the workflow.
Topics:
· Mapping Actions to User Roles
When you map Case Statuses to an Action, then that action is only available when a case is in the mapped statuses.
To map the Action to a Status, follow these steps:
1. Navigate to the Case Actions/Statuses page.
2. Select the Actions Mapping tab.
3. Select the Action from the Select Non-Status Changing Case Action drop-down list. The Selected Statuses list is updated with all the available statuses.
4. Select the
Status from the Available Statuses list and
move to the Selected Statuses list. You can
move multiple statuses at once by using either the Ctrl or Shift button
and selecting multiple (or all) statuses from the Available
Statuses list and clicking Select
. You can move all statuses
by clicking Select All
5. Click Save
. A confirmation message
is displayed: Saved Successfully.
Reset
discards
the data entered by you and resets the contents to their original state.
Saved changes cannot be reset using this option. This is applicable only
when you are editing and want to reset the data.
When a User Role, such as Supervisor or Analyst, is mapped to an Action, then that particular User Role is allowed to perform the mapped action. Each Action can be mapped to multiple User Roles. User Roles must also be mapped to an appropriate User Group. See Identity Management for more information.
To map the Action to a User Role, follow these steps:
2. Select the Action Mapping tab.
3. Select the Action from the Select Non-Status Changing Case Action drop-down list. The Selected User Role list is updated with all the available User Role.
4. Select the
User Role from the Available User Role list
and move it to the Selected User Role list.
You can move multiple User Roles at once by using either the Ctrl
or Shift button and selecting multiple (or all) user roles from the Available User Roles list and clicking Select
5. Click Save
6. Reset
discards the data entered by you and
resets the contents to their original state. Saved changes cannot be reset
using this option. This is applicable only when you are editing and want
to reset the data.
