Configuring Client Properties Settings
Primavera P6 Administrator Setup Tasks > About the Configurations Tab in the Primavera P6 Administrator
You can use the client properties to configure settings controlling how P6 communicates with the application server.
To set your log settings:
- Open the Primavera P6 Administrator.
- In the Configurations drop-down list, select your configuration.
- In the sidebar select Client Properties.
- Select Compress HTTP Content to improve download time over WAN networks, or clear the option if download time is not an issue for you, but freeing up server CPU availability is important.
- Optionally, in the HTTP Server And Port Override field, enter the HTTP front-end server and port to which P6 will connect.
Notes:The HTTP Server And Port Override is only required if navigation links in P6 are using an incorrect protocol, host, or port.
- In the Ajax Request Wait Timeout section, specify how long the server should wait for Business Process Management workflows and Action Required tabs to respond.
Related Topics
Configuring Localization Settings
Configuring Session Management Settings
Configuring Database Instance Settings for On-Premises
Configuring Thread Pool Settings
Configuring AutoVue without VueLink
Configuring Web Proxy Settings
About Application Settings in the Primavera P6 Administrator
About the Primavera P6 Administrator Services Settings
Configuring P6ProCloudConnect Settings
Configuring GeoCodeProvider Settings
Configuring Integration API Server Settings
About Configuring P6 EPPM Web Services in the Primavera P6 Administrator
Configuring P6 Team Member Settings
Configuring Diagnostics Settings
Last Published Monday, July 14, 2025
