Configuring AutoVue without VueLink
Primavera P6 Administrator Setup Tasks > About the Configurations Tab in the Primavera P6 Administrator
Configuring AutoVue without VueLink is the native AutoVue implementation. To use this implementation, you will configure a single AutoVue server that is common across all database instances.
Notes:
- When you configure AutoVue without VueLink, you are creating global AutoVue settings. These settings override any individual settings you may have created to configure AutoVue with VueLink.
- When upgrading to Version 24 from 15 R2 or earlier, AutoVue connection details are lost and must be entered again.
To configure AutoVue without VueLink, complete the following steps:
- Open the Primavera P6 Administrator.
- In the Configurations drop-down list, select your configuration.
- In the sidebar select Document Viewing.
Note: Changes to these settings require you to restart the P6 server.
- Select Enable. The default value is unselected.
Notes:
- SSL mode does not work when the Enable option is set to false.
- By default, the ESAPI resources that come with VueLink is used. You can change the location of the resource files by using
-Dorg.owasp.espai.resources JAVA_OPTIONSin the WebLogic application server or in the setDomainEnv script. - By default,
dmsstamp.iniand the oracle sample stamp from VueLink is used to create markup. You can change the location of thedmsstamp.inifile, which contains the stampfile location, using-Dexternal.csi.intellistamp.def.location JAVA_OPTIONSin the WebLogic application server or in thesetDomainEnvscript. - If using Oracle Access Manager with your P6 EPPM deployment, add following context roots to the Oracle Access Manager exclusion list:
/p6/VueServlet/**/p6/jvueDMS/**/p6/P6AutoVueJNLPLauncher/**/p6/av_cert.pem
For more information about protecting your resources using Oracle Access Manager's exclusion list, see the "Protecting Your Resources" chapter in the Oracle Access Manager Configuration Guide.
- In the Host Name field, enter the hostname for the server where AutoVue is installed.
Note: Do not put a / at the end of the URL.
- In the Host Port field, enter the port for the server where AutoVue is installed. The default port is 5099.
- Restart the P6 server.
Related Topics
Configuring Localization Settings
Configuring Session Management Settings
Configuring Database Instance Settings for On-Premises
Configuring Thread Pool Settings
Configuring Client Properties Settings
Configuring Web Proxy Settings
About Application Settings in the Primavera P6 Administrator
About the Primavera P6 Administrator Services Settings
Configuring P6ProCloudConnect Settings
Configuring GeoCodeProvider Settings
Configuring Integration API Server Settings
About Configuring P6 EPPM Web Services in the Primavera P6 Administrator
Configuring P6 Team Member Settings
Configuring Diagnostics Settings
Last Published Monday, July 14, 2025
