Importing a Project in SDEF Format
Importing an SDEF file to P6 Professional is a two-step process. First you must convert the SDEF file to XER, then you can import the XER file into P6 Professional. Once the file is imported, the project is accessible using P6 Professional.
To convert and import an SDEF file:
  1. Double-click P330XERConvert.exe.
    Refer to SDEF Conversion Utilities for information about where to get the utility.
  2. In the SDEF to XER Project Conversion dialog:
    1. Choose SDEF as the conversion type, then click Next.
    2. Click Browse to select the SDEF file you want to convert, then click Next.
    3. Click Browse to select the XER file you want to overwrite or enter a new XER filename, then click Next.
    4. Click Finish.
  3. Import the XER file to P6 Professional.
    For specific instructions on importing XER files, refer to the Importing and Exporting Guide.
Related Topics
Considerations When Converting a Project to SDEF
Generating a Project in SDEF Format
Last Published Monday, December 8, 2025
