Copy and paste a resource
  1. Choose Enterprise, Resources.
  2. If necessary, choose View, Filter By, All Resources, to display all resources.
    If resource security is enabled you can only view resources you have access to. Therefore, you can copy and paste a resource only to the hierarchy you have access to.
  3. Choose View, Group and Sort By, Default.
  4. Select the resource you want to copy, then choose Edit, Copy.
  5. Select the resource to which you want to add the copy, then choose Edit, Paste.
    Choose Sub-Resources to copy all resources contained in the resource you want to copy.
    Choose Role Assignments to copy the resource's role assignments.
    Choose Prices to copy the resource's price information.
Tip
Related Topics
Cut and paste a resource
Copy Resource Options dialog box
Introduction to Resource Security
Root Node
Last Published Friday, December 12, 2025
