Cut and paste a resource
- Choose Enterprise, Resources.
- If necessary, choose View, Filter By, All Resources, to display all resources.
- Choose View, Group and Sort By, Default, to display the resource hierarchy.
If resource security is enabled you can only view resources you have access to. Therefore, you can cut and paste a resource only to the hierarchy you have access to. - Select the resource you want to cut and paste, then choose Edit, Cut.
- Select the resource to which you want to add the cut resource, then choose Edit, Paste.
Note
- When you cut and paste a resource, the resource's activity assignments are also cut and pasted.
- You can cut and paste any resources you have access to, except your root node. However, keep in mind that changing the resource hierarchy changes the resource's accessibility for users previously assigned to those nodes.
Related Topics
Introduction to Resource Security
Last Published Friday, December 12, 2025
