Risks view (P6 Professional Only)
Use the Risks view to add, edit, and delete risks for the open project. You can also assign risks to activities, define risk impact, select a response, and define new impacts based on the response. You can customize the columns that display in the risk table, and you can group, sort, and filter risks.
To display the Risks view, do one of the following:
When working in the Risks view, you can:
Related Concepts
Related Tasks
You can perform all of the following tasks in the Risks view:
Related Topics
Project Toolbar
Edit Toolbar
Menu bar
Risks (P6 Professional Only)
Bottom Layout Toolbar
Layout Toolbar
Risks Details (P6 Professional Only)
Root Node
Current Project Resources
Introduction to Resource Security
Removing risk assignments from activities (P6 Professional Only)
Modifying a risk (P6 Professional Only)
Responding to a risk (P6 Professional Only)
Assigning a risk to an activity (P6 Professional Only)
Creating Risks (P6 Professional Only)
Last Published Friday, December 12, 2025
