View past period actual data in spreadsheets
You can view past period actual data spread by financial period in the Resource Usage Spreadsheet and Activity Usage Spreadsheet.
  1. Right-click in the spreadsheet, then choose Spreadsheet Fields, Customize.
  2. In the Available Options section, expand either the Cumulative or Time Interval sections, then expand the Financial Period Value section.
  3. Move the Financial Period Value fields you want to the Selected Options section.
  4. Click Ok.
Tip
Note
You cannot edit past period actual data in spreadsheets. You can edit past period actuals in columns of the Activity Table, Resource Assignments window, and the Activity Details, Resources tab.
Related Topics
Manually enter future period assignment values
Edit past period actual data
Last Published Friday, December 12, 2025
