Work Breakdown Structure window
Use the Work Breakdown Structure window to create, view, and edit the open project's work breakdown structure (WBS). You can group and sort the WBS, customize columns, and open and save WBS layouts.
To display the Work Breakdown Structure window, do one of the following:
Refer to the following sections of this topic for information and links to concepts and tasks about working with the WBS in the Work Breakdown Structure window:
Working in the Work Breakdown Structure window
When working in the Work Breakdown Structure window, you can:
Tip
WBS concepts
The following concepts relate directly to working with the WBS:
WBS tasks
You can perform all of the following tasks in the Work Breakdown Structure window:
Related Topics
Menu bar
Project Toolbar
Move Toolbar
Bottom Layout Toolbar
WBS Details
Top Layout Toolbar
Layout Toolbar
Edit Toolbar
WBS status types
Using weighted milestones in the work breakdown structure
Organizational breakdown structure (OBS) overview
OBS security
Earned Value
Calculating earned value using resource curves or manual future period buckets
Change the work breakdown structure table display
Change the work breakdown structure chart display
Assign work products and documents to a WBS element from the Work Breakdown Structure window
Assign WBS weighted milestones
Assign an OBS element to a WBS element
Add a WBS element
View the WBS
Save a layout in the Projects or Work Breakdown Structure window
Remove work product and document assignments in the Work Breakdown Structure window
Open a work product or document from the Work Breakdown Structure window
Move around the WBS chart
Edit a work breakdown structure element
Display work breakdown structure details
Determine a WBS element's status
Delete a work breakdown structure element
Define earned value settings for a specific work breakdown structure element
Cut and paste a work breakdown structure element
Copy and paste a work breakdown structure element
Last Published Friday, December 12, 2025
