Configuring and Running Primavera Unifier Publication Services
If you are using Primavera Unifier as a data source, Primavera Data Warehouse relies on data from the Primavera Unifier Staging Tables and related publication services. You must configure and run publication services prior to running the STARETL process. This enables users to control what data to calculate and store and how often the data is updated.
Note: For detailed instructions on publishing data in Primavera Unifier, see "Publishing Unifier Data to Analytics" in the Primavera Unifier Administration Guide.
To configure publication services in Primavera Unifier, complete the following steps:
  1. Sign in to Primavera Unifier with an account that has administration privileges (ootbadmin).
  2. Go to the Company workspace.
  3. Change the mode from user mode to admin mode.
  4. Open the Analytics module.
  5. Click the Schedule icon on the toolbar.
  6. On the Schedule Setup pane, set the data update frequency.
  7. If you have made any changes to the data definition or the data mapping fields, select the Refresh all data check box.
    Note: If you choose to refresh all data, you may want to deselect the Refresh all data check box after the run is complete.
  8. Click OK.
  9. If you are using Oracle Data Integrator (ODI), complete the additional steps for Configuring ODI Source User and Source Schema Privileges in the Primavera Data Warehouse Installation and Configuration Guide for On-Premises.
Related Topics
Configuring Primavera Unifier for Primavera Data Warehouse
Creating History Data for Primavera Unifier
Setting Up Business Processes for Analytics
Setting Up Cash Flow Data for Analytics
Setting Up Cost Sheet Data for Analytics
Setting Up Generic Cost Sheet Data for Analytics
Setting Up P6 Summary Sheets Data for Analytics
Setting Up Shell Data for Analytics
Setting Up Space Manager Data for Analytics
Setting Up Vendor Data for Analytics
Last Published Monday, December 15, 2025
