Setting Up P6 Summary Sheets Data for Analytics
You can select the P6 Data Sources that you want to use in Analytics.
To add P6 data sources:
  1. Sign in to Unifier with administration privileges.
  2. In the navigation pane, select Analytics.
  3. In the Name column, select P6 Summary Sheets and then click Open.
  4. In the Analytics P6 Summary Sheets Setup window, click Add.
  5. In the Select P6 Data Sources for Analytics field, select any of the available data sources, and then click OK.
    If fields overlap between the CBS Shells and the existing P6 Summary Sheets, then the system-defined fields in the P6 Summary Sheets will be used.
For more details, see the Primavera Unifier General Administration Guide.
Related Topics
Configuring Primavera Unifier for Primavera Data Warehouse
Configuring and Running Primavera Unifier Publication Services
Creating History Data for Primavera Unifier
Setting Up Business Processes for Analytics
Setting Up Cash Flow Data for Analytics
Setting Up Cost Sheet Data for Analytics
Setting Up Generic Cost Sheet Data for Analytics
Setting Up Shell Data for Analytics
Setting Up Space Manager Data for Analytics
Setting Up Vendor Data for Analytics
Last Published Monday, December 15, 2025
