Document ID and Tax ID
This ERD (see the following figure) illustrates how document identification numbers are generated and assigned to each user. Typically, document IDs are used to support a legal requirement to print unique numbers on legal documents, such as invoices and receipts. Governments provide specifications on the document ID formats, and these formats can be used to generate a document ID mask within the Siebel application. After the mask is created, it must be assigned to individual users who have the authority to use them. When the user prints from the handheld device, a unique sequence of numbers are printed onto each legal document defined with the document ID mask.
The following table lists the entities in this ERD and their corresponding tables.
| Entity | Table |
Account |
S_ORG_EXT, S_PARTY |
Authorized Product |
S_ORG_PROD |
Document Mask Component |
S_DOC_NUM_SEG |
Document Types |
S_DOC_NUM |
Document Values |
S_DOC_NUM_VAL |
Invoice |
S_INVOICE |
Order |
S_ORDER |
Order Item |
S_ORDER_ITEM |
Price List |
S_PRI_LST |
Price List Item |
S_PRI_LST_ITEM |
