Managing Room Block Floor Negotiation Rates for a Quote Meeting Package
For a room block that is part of a quote, event managers can change the floor negotiation rates. To manage room block floor negotiation rates for a quote meeting package, follow this procedure.
  1. Navigate to the Quotes screen, then the List view.
  2. In the Quotes list, query for and select a quote with an associated meeting package.
  3. In the Quote record, click the link in the Name field, and then click the Room Blocks view tab.
  4. In the Room Blocks list, query for records with one of the following values:
    • Core check box is selected.
    • Package field value of IS NOT NULL.
  5. Select a core room block record and click the Negotiation Rates - Manager subview tab.
  6. In the Negotiation Rates - Manager list, click Calculate Rates.
    Siebel Hospitality updates the fields, as appropriate, from the rates you entered.
  7. Select a record and view the information in the fields.
For more information about room block floor negotiation rates in a quote, see Changing the Floor Negotiation Rates.
