Using USE INDEX HINTS and USE ESSENTIAL INDEX HINTS: Example
This topic is part of Troubleshooting Siebel EIM Performance.
See also:
Using the USE INDEX HINTS and USE ESSENTIAL INDEX HINTS Parameters
Using USE INDEX HINTS and USE ESSENTIAL INDEX HINTS: Criteria for Passing Indexes to the Database
This following table illustrates the results achieved for an SQL statement with index hints and without index hints. This example was performed on Microsoft SQL Server.
SQL User Name |
CPU |
Reads |
Writes |
Duration |
Connection ID |
SPID |
549625 |
38844200 |
141321 |
626235 |
516980 |
9 |
UPDATE dbo.S_ASSET5_FN_IF
SET T_APPLDCVRG__RID =
(SELECT MIN(BT.ROW_ID)
FROM dbo.S_APPLD_CVRG BT (INDEX = S_APPLD_CVRG_U2)
WHERE (BT.COVERAGE_CD = IT.CVRG_COVERAGE_CD AND
BT.TYPE = IT.CVRG_TYPE AND
BT.ASSET_ID = IT.T_APPLDCVRG_ASSETI AND
(BT.ASSET_CON_ID = IT.T_APPLDCVRG_ASSETC OR
(BT.ASSET_CON_ID IS NULL AND IT.T_APPLDCVRG_ASSETC IS NULL)) AND
(BT.INSITEM_ID = IT.T_APPLDCVRG_INSITE OR
(BT.INSITEM_ID IS NULL AND IT.T_APPLDCVRG_INSITE IS NULL))))
FROM dbo.S_ASSET5_FN_IF IT
WHERE (CVRG_COVERAGE_CD IS NOT NULL AND
CVRG_TYPE IS NOT NULL AND
T_APPLDCVRG_ASSETI IS NOT NULL AND
IF_ROW_BATCH_NUM = 10710001 AND
IF_ROW_STAT_NUM = 0 AND
T_APPLDCVRG__STA = 0)
SET STATISTICS PROFILE ON
GO
SET STATISTICS IO ON
GO
select
