Using the USE INDEX HINTS and USE ESSENTIAL INDEX HINTS Parameters
This topic is part of Troubleshooting Siebel EIM Performance.
Perform testing with the IFB file parameters USE INDEX
HINTS and USE ESSENTIAL INDEX HINTS, trying
both settings (TRUE and FALSE).
The default value for USE INDEX HINTS is FALSE. The default value for USE ESSENTIAL INDEX
HINTS is TRUE.
USE INDEX HINTS within each
one.If these parameters are set to FALSE, then Siebel
EIM does not generate hints during processing. By setting the value
to FALSE, you can realize performance gains if the TRUE setting means that hints are being generated that direct
the database optimizer to use less than optimal indexes. Siebel EIM
processing must be tested with both the TRUE and FALSE settings to determine which one provides better performance
for each of the respective Siebel EIM jobs.
USE INDEX HINTS parameter is applicable
only for Oracle Database. The USE ESSENTIAL INDEX HINTS parameter is applicable only for Oracle Database and Microsoft SQL
Server.These two parameters work for different queries, so you have to enable both to get all of the index hints on Oracle Database.
Further information is provided as follows:
