GetProductId Method
This method gets the root Product ID of the complex object instance.
Input Arguments
  • ObjId. The unique identifier of the complex object header (for example, Quote ID).
  • RootId. The unique identifier of the complex object root (for example, Quote Line Item row Id).
  • (Optional) Version. Version arguments are used only when testing a customizable product version that is different from the currently released version.
Output Arguments
The product Id is returned as a property of the output property set, as follows:
< Product Id="value" />
