GetRootPath Method
This method returns the path of the complex object instance root.
Input Arguments
ObjId. The unique identifier of the complex object header (for example, Quote ID).
RootId. The unique identifier of the complex object root (for example, Quote Line Item row Id).
(Optional) Version. Version arguments are used only when testing a customizable product version that is different from the currently released version.
Output Arguments
The root path is returned as a property of the output property set, as follows:
< Path="value" />
