HasGenerics Method
This method returns generics and children flags for an item. A port has generics if the required cardinality is greater than the current cardinality and no default product is specified.
Input Arguments
ObjId. The unique identifier of the complex object root (for example, Quote ID).
RootId. The unique identifier of the complex object root (for example, Quote Line Item row id).
IntObjName. The name of the integration object.
(Optional) Version. Version arguments are used only when testing a customizable product version that is different from the currently released version.
Port Item Id. The ID for the port item that will have either children or generics.
Path. The path to the parent item of interest.
Output Arguments
HasGenerics. Y is present if it does, not present if it does not.
HasChildren. Y is present if it does, not present if it does not.
