Commands
Procedural steps that ask you to execute a command must be performed as follows, unless specified otherwise:
  • Windows. Open a Command Prompt window and use the cd command to make the specified directory the current directory. Enter the command.
    Do not use the Windows File Explorer to navigate to the directory and do not run the command by entering it in the Run window in the Start Menu.
  • UNIX. In a shell window, make the specified directory the current directory, source the siebenv script, then enter the command.
Use lowercase for all filenames, directory names, path names, parameters, flags, and command-line commands, unless you are instructed otherwise.
