Roadmap for Setting Up Siebel Mobile Disconnected Applications
To set up Siebel Mobile disconnected applications, review and perform the following tasks:
Review Load Balancing before setting up Siebel Mobile disconnected applications.
Setting Siebel Application Object Manager Parameters for Siebel Mobile
Set up the business component data filters for Siebel Mobile.
For more information, review Guidelines for Developing Data Filters for Siebel Mobile and see Data Filtering for Siebel Mobile.
Set up the default fields for non-UI business component fields.
The Handheld Business Service only downloads fields that are exposed in the UI. To download the non-UI fields, you must configure the field details. For more information, see Configuring Application Settings for Siebel Mobile.
Set up the default Business Objects to extract the business objects and the business components which are not extracted as part of UI.
The Handheld Business Service only downloads business components that are exposed in the UI. To download any additional non-UI fields, you must configure the default business objects in the Administration - Siebel Mobile, Application Administration, Settings view. For more information, see Configuring Application Settings for Siebel Mobile.
