Read Siebel Message Method Arguments
This topic describes the input and output arguments for the Read Siebel Message method of the EAI XML Read from File business service.
Input Arguments
The following table describes the input arguments for the Read Siebel Message method of the EAI XML Read from File business service.
Display Name Name Data Type Description
File Name
FileName
String
The name of the file to be read. This is a required field.
Integration Object Name
IntObjectName
String
Name of the Integration Object to use in cases where the Siebel Message header is not present.
Integration Object Lookup Rule Set
IntObjectLookupRuleSet
String
Rule Set for the EAI Dispatcher Service for finding the Integration Object Name in cases where the Siebel Message header is not present.
External Entity Directory
ExternalEntityDirectory
String
Directory to use for finding external entities referenced in the XML document, such as DTDs.
Truncate Field Values
TruncateFieldValues
String
Default is True. If True, then truncate any fields longer than their maximum size. If False, report fields that are too long as errors.
Ignore Character Set Conversion Errors
IgnoreCharSetConvErrors
String
Default is False. If the Siebel application cannot represent a given character set, such as the local code page character set, then conversion errors are logged, including a warning log entry. When set to True, only a warning message is logged.
Process Elements Only
ProcessElementsOnly
String
Default is False. If set to True, then processing of attributes is skipped.
Output Arguments
The following table describes the output arguments for the Read Siebel Message method of the EAI XML Read from File business service.
Siebel Message
SiebelMessage
Hierarchy
The Integration Object Hierarchy converted from XML.
XML Character Encoding
XMLCharEncoding
String
Outputs XML character encoding to use. If encoding is blank or not supported, then an error is produced.
