Read Property Set Method Arguments
This topic describes the input and output arguments for the Read Property Set method of the EAI XML Read from File business service.
Input Argument
The following table describes the input argument for the Read Property Set method of the EAI XML Read from File business service.
Display Name | Name | Data Type | Description |
File Name |
FileName |
String |
The name of the file to be read. This is a required field. |
Output Argument
The following table describes the output argument for the Read Property Set method of the EAI XML Read from File business service.
Child type of the hierarchical process property containing the entire property set, service method arguments, and child property set. |
Hierarchical |
The entire output property set. You must manually create and name this output argument if it is required by your business needs. |
