Read XML Hierarchy Method Arguments
This topic describes the input and output arguments for the Read XML Hierarchy method of the EAI XML Read from File business service.
Input Arguments
The following table describes the input arguments for the Read XML Hierarchy method of the EAI XML Read from File business service.
Display Name Name Data Type Description
File Name
FileName
String
The name of the XML file to read. This is a Required field.
Escape Names
EscapeNames
String
Invalid characters in XML tags will be escaped, using Siebel CRM’s internal escape format.
  • If True, then process Escape characters (this is the default).
  • If False, then do not process Escape characters.
External Entity Directory
ExternalEntityDirectory
String
Directory for external entities such as DTD files.
Ignore Character Set Conversion Errors
IgnoreCharSetConvErrors
String
Default is False. If the Siebel application cannot represent a given character set, such as the local code page character set, then conversion errors are logged, including a warning log entry. When set to True, only a warning message is logged.
Output Arguments
The following table describes the output arguments for the Read XML Hierarchy method of the EAI XML Read from File business service.
XML Character Encoding
XMLCharEncoding
String
Character encoding of the XML document, detected by the converter independent of the parser.
XML Hierarchy
XMLHierarchy
Hierarchy
The XML Hierarchy property set.
