Changing System Preferences for the Cycle Counting Engine
You can change the system preferences for the Cycle Counting Engine.
This task is a step in Process of Administering Cycle Counting.
To change the system preferences for the Cycle Counting Engine
  1. Navigate to Administration - Application screen, then the System Preferences view.
  2. Select a system preference for the Cycle Counting Engine.
    For more information about the system preferences for the Cycle Counting Engine, see the following table.
  3. In the System Preference Value field, enter a new value.
  4. To implement the changes to the system preferences, restart the Field Service server.
The following table describes some system preferences for the Cycle Counting Engine.
System Preference Name Default Value Description
BucketAvailCDtobeCounted
OnHand, Customer-Owned
Specifies the valid values for the availability code of the inventory level. The values come from the Bucket Availability Code LOV, and individual values are LIVs.
BucketStatusCDtobeCounted
Good
Specifies the valid values for the status code of the inventory level. The values come from the Bucket Status Code LOV, and individual values are LIVs.
Only the inventory levels (buckets) with an Availability field value and a Status field value that match the values in these system preferences are included in the cycle counting process.
