Setting Component Job Parameters for the Cycle Counting Engine
Follow the procedure in this topic to set the component job parameters for the Cycle Counting Engine. For more information about server components, component parameters, and setting repeating component jobs, see Siebel System Administration Guide.
This task is a step in Process of Administering Cycle Counting.
To set the component job parameters for the Cycle Counting Engine
  1. Navigate to the Administration - Server Management screen, Jobs, then the Job Detail view.
  2. Create or edit a component job for the Field Service Cycle Counting Engine (alias FSCyccnt) server component.
    If you want to set the component job parameters for the Replenishment Engine, then create or edit a component job for the Field Service Replenishment Engine (alias FSRepl) server component.
  3. Add or modify the server component parameters, as needed.
    For more information about the applicable parameters, see Parameters for the Cycle Counting Engine and Parameters for the Replenishment Engine.
