Changing Cursor Configuration Parameter Values
This topic describes how to change the cursor configuration parameter values. You can change the cursor configuration parameter for Siebel clients in the following locations:
  • Application configuration (.cfg) files for the Siebel Developer Web Client and Siebel Mobile Web Client.
  • From the command line for the Siebel Web Client.
    Because the Siebel Web Client does not have an application configuration file, it uses the configuration parameter values specified for the Enterprise Server; these values are applied to all server components and the Web Client.
  • Application configuration (.cfg) file for Siebel Tools.
  • At the business component level in Siebel Tools.
For information on overriding the MaxCursorSize parameter value from within a Siebel script, see 478276.1 (Article ID) on My Oracle Support. This document was formerly published as Siebel Technical Note 592. For information on Siebel clients, see Siebel Installation Guide. For more information on Siebel Tools, see Using Siebel Tools.
