LS Pharma Call Products Detailed Alloc VBC User Properties
Virtual business components (VBCs) are used to view data from an external system in Siebel Business Applications. Using this mechanism, no replication within the Siebel database is required.
The following table describes the user properties that apply to the LS Pharma Call Products Detailed Alloc VBC (Virtual Business Components).
Name | Value | Description |
Qty Field |
Priority |
Holds the name of the field to save from VBC to BC when a value of the field is modified or added. |
Copy Field 3 |
Name |
Holds the name of the field to populate from Source BusComp to this VBC and to copy from VBC to Parent BusComp. |
Copy Field 4 |
Indication |
Source BusComp |
LS Pharma My Products List |
Holds the name of the parent Products BC, which is using to get the values for the VBC. |
Parent BusComp |
Pharma Call Products Detailed |
Holds the exact name of the parent Products Detailed BC. |
Copy Field 2 |
Product Allocation Id |
Copy Field 1 |
Priority |
Query Field 1 |
Holds the name of the field to save from VBC to BC when a value for this field is modified or added. |
Qty Field 1 |
Indication |
Copy Field 6 |
Alloc Start Date |
Copy Field 7 |
Alloc End Date |
