LS Pharma Call Products Detailed VBC - CE User Properties
The following table describes the user properties that apply to the LS Pharma Call Products Detailed VBC - CE.
Name Value Description
Template Fields
Name, Priority, Indication
Specify the list of fields in the VBC which needs to be updated when a smart call template is applied to the call
Sort Spec:Pharma Call Products Detailed - CE
Product Id
Specify the sort specification to be applied on the Call Product BC.
VBC Field Map:Pharma Personal Products - CE
Name, Product|Allocation Id, Id|Product Id, Product Id|Indication, Indication Other|Order By, Order By
Specify the mapping between the VBC fields and the Personal Allocation BC fields. The mapping syntax is <VBC Field Name>, <Personal Allocation BC Field Name> [|<VBC Field Name>, <Personal Allocation BC Field Name>].
VBC Field Map:Pharma Call Products Detailed - CE
Name, Name|Product Id, Product Id|Allocation Id, Allocation Id|Priority, Priority|Indication, Indication
Specify the mapping between the VBC fields and the Call Product BC fields. The mapping syntax is <VBC Field Name>, <Call Product BC Field Name> [|<VBC Field Name>, <Call Product BC Field Name>].
Search Spec: Pharma Personal Products - CE
[Start Date] <= '$StartDate$' AND([End Date] IS NULL OR [End Date] >= '$StartDate$')
Specify the search spec to be applied on the Personal Allocation BC. $StartDate$ is the key word which will be replaced at run time with the actual call date.
Specify the name of the BC that holds information about the products allocated to the sales rep for detailing.
Call Product BC
Specify the name of the BC that holds information about the products detailed in the call.
