Driver Parameters for the Siebel - Unity Data Export Engine
The following table provides the definitions and default values for several driver parameters for the Siebel - Unity Data Export engine.
Settings for Configuring Driver Parameters for the Siebel - Unity Data Export Engine
Parameter Name Default Value Required Purpose or Definition
Batch Split Size
1000
Y
The number of records representing the batch size threshold for each batch during initial data export. If the batch size exceeds this number of records, then this batch is split into multiple batches, with a separate job for each batch.
Batch Submit Size
100
Y
The value must be lower than the value of Batch Split Size. Each job fetches this many records and invokes the adapter service to write the data into a CSV file. A new job repeats this process until all records in all batches have been processed.
Charset
UTF-8
Y
The character set of the data. Supported values are UTF-8 or UTF-16.
Delete File After Upload
Y
N
Deletes the CSV file after import if the value is Y or the parameter does not exist. Otherwise, the file is not deleted.
ExportOnly
N
Y
If the value is N, then CSV files are uploaded in OOS. Otherwise, the CSV files are generated in the path specified in the filepath parameter.
bucketname
Not applicable
N
The name of the OOS bucket where the CSV file is to be uploaded. This parameter is required only where ExportOnly is set to N.
directory
Not applicable
N
The name of the directory under the OOS bucket. If this parameter is left empty, the file is uploaded into the OOS bucket at the top level.
filepath
Not applicable
Y
The file path where the CSV files are created. This path must be accessible to the Siebel Server where the Search component group is enabled. Also, it must be accessible to the Configuration Agent that runs the JBS.
fingerprint
Not applicable
N
The fingerprint of the OOS user.
key_file
Not applicable
N
The private key file of the OOS user. This path must be accessible to the Configuration Agent that runs the JBS.
namespace
Not applicable
N
The name space of the OOS.
region
Not applicable
N
The name of the OOS region.
tenancy
Not applicable
N
The name of the OOS tenancy.
userId
Not applicable
N
The user ID of the OOS.
