About Scenario Tester and Workspace Projects
Scenario Tester allows you to test the validity of your customizable product or simple product with attributes at any time that you specify (past, current, or future) and to create a number of quotes, orders, and agreements that will be used to test your customizable product. Each quote, order, agreement or asset is a scenario used for testing.
Before you test products using Scenario Tester, you must create a workspace project, which includes:
  • Contents list. Add the objects you want to test.
  • Scenarios list. Define the test Quotes, Sales Orders, Service Orders, and Agreements that you are using to test these objects.
