Working with Versioned and Unversioned Objects
Scenario Tester can test:
  • Versioned objects. You can test customizable products, classes, and attribute definitions.
    • If the objects are part of the active Workspace Project, Scenario Tester uses the version in the Workspace Project, even if it is unreleased.
    • If objects are not part of the Workspace Project, Scenario Tester uses the released version of the object.
      Note: Scenario Tester uses objects that are not part of the Workspace Project if objects that are part of the Workspace Project are dependent on them. For example, if you add a product with attributes to the Workspace Project, but do not add the Class that the product inherits its attributes, Scenario Tester uses the released version of that Class.
  • Unversioned objects. Scenario Tester tests the eligibility, compatibility, and pricing rules for unversioned objects, using the Base Date to determine whether a particular item must be retrieved.
