Assigning the New UI Control Template
To assign the new Web template to a group item, you first add the template to the Pick UI Style dialog box. Then you select it as the template for an item in the group.
To assign the new UI control template
Click the magnifying icon.
This opens the Pick User Interface Style window.
Click the plus icon (+).
In the Template field, click the magnifying icon.
In the Query field, enter an asterisk (*) to list all UI Control templates.
Select the template you created in Creating a New UI Control Template.
In the Pick User Interface Style window, enter the following information:
Name. Enter a descriptive name. For example: Modified Tab Theme.
Template. Enter the filename of the template you created.
Description (Optional). Enter a brief description of the template.
Click Save and OK.
In Group Item List, save the revised record.
