Defining a UI Property for the Item
The last step is to assign the variable in the new Web template to the item. Then you enter a value for the variable. The value you enter is what displays in a configuration session.
For example, if you assigned the template to a relationship, you must define a UI property for each item in the relationship.
To define a UI Property for the item
Click the Properties view tab.
In the box displaying the contents of the customizable product, select the item on which you want to define the UI property.
In Item Display Properties, add a new record and complete the necessary fields:
Name. Enter the name of the UI property variable. Do not include the period (.) that begins the name.
Value. Enter the value you want to the variable to have for this item.
Save the new record.
Open the Item Display Properties menu and click Validate.
This starts a configuration session. Verify that the item names display correctly.
