Creating a Part Number Generation Record
First Create a part number generation record. This record names the part number generation method and specifies whether the method is dynamic or predefined.
This task is a step in Process of Creating Dynamically Generated Smart Part Numbers.
To create a part number generation record
  1. Navigate to the Administration - Products screen, then the Product Classes view.
  2. In the Product Classes list, select the desired product class.
  3. Click the name in the Smart Part Number field.
    The name is a hyperlink. The Smart Part Number list appears.
  4. In the Smart Part Number list, add a new record and complete the necessary fields, described in the following table.
    Field Comments
    Name
    Enter a name for the part number generation method.
    Type
    Select Dynamic.
