Defining the Part Number Templates
Next, define the part number template.
This task is a step in Process of Creating Dynamically Generated Smart Part Numbers.
To define the part number template
  1. In the Name field of the Smart Part Number record, click the name you entered.
    The name is a hyperlink. The Part Number Method view appears.
  2. In the Part Number Template list, add a new record and complete the necessary fields, described in the following table.
    Field Comments
    Pre-Fix
    Enter a static text that appears before all other parts of the smart part number generated by the application
    Attribute Name
    Select the attribute for this section
    Post Fix
    Enter a static text that appears after all other parts of the smart part number generated by the application
    Abbreviation Method
    Select an abbreviation method for the attribute mapping
    Sequence
    Enter a sequence. The sequence determines the order of the section in the part number.
  3. Repeat Step 2 for each section you want to include in the part number.
