Creating a Part Number Generation Record
First, create a part number generation record. This record names the part number generation method and specifies whether the method is dynamic or predefined.
This task is a step in Process of Creating Predefined Smart Part Numbers.
  1. Navigate to the Administration - Products screen, then the Product Classes view.
  2. In the Product Classes list, select the desired product class.
  3. Click the link in the Smart Part Number field.
  4. In the Part Number Definitions list, add a new record and complete the necessary fields, described in the following table.
    Field Comments
    Name
    Enter a name for the part number generation method.
    Type
    Select Predefined.
