Selecting the Attributes for Predefined Part Numbers
The next step is to select the desired attributes.
This task is a step in Process of Creating Predefined Smart Part Numbers.
To select the desired attributes
In the part number definition Name field, click the name you entered.
The name is a hyperlink. The Part Number Method view appears.
In the Attributes list, add a new record and, in the Attribute Name field, select the desired attribute.
Repeat Step 2 until you have added all the attributes that you want to use for defining part numbers.
