Deleting Attribute Definitions
You cannot delete an attribute definition. If you no longer want to use the attribute, you can deactivate all versions
Before doing this, verify that the attribute is not used in any configuration rules, or for attribute-based pricing.
To expire or deactivate an attribute definition
Navigate to the Administration - Product screen, then the Attribute Definitions view.
In the Attribute Definitions list, select the desired attribute definition.
In the Versions view, deselect the Active checkbox for the Work Space version of the attribute definition.
Release the Work Space version.
