Editing Attribute Definitions
When you edit attribute definitions, you modify the attribute domain.
To edit an attribute definition
Navigate to the Administration - Product screen, then the Attribute Definitions view.
In the Attribute Definitions list, select and lock the desired attribute definition.
In the Versions list, click the Work Space version.
In the Details view, edit the definitions as necessary.
