Displaying RAL in the Constraints View
You can revise the Constraints list to add a field that displays the Rule Assembly Language (RAL) translation of your template rules. This is a useful way to learn how to use RAL to write configuration rules.
You must use Oracle's Web Tools to add the field to the Constraints record, and then recompile the siebel.srf file. You must be familiar with creating and modifying applets in Oracle's Web Tools before performing this procedure.
To revise the Constraints view, perform the following tasks:
  1. Locate the Constraints View Applet
  2. Modify the Constraints View Applet
