Dynamically Making Siebel Configurator Controls Read-Only
You make Siebel Product Configurator controls read-only in the same way that you hide them. For more information, see Dynamically Showing and Hiding Siebel Product Configurator Controls.
The only difference is that, in Step 3 in Dynamically Showing and Hiding Siebel Product Configurator Controls, you create a property for the control named DynamicReadOnly instead of DynamicHide.
