Example of Dynamically Showing and Hiding Siebel Configurator Controls
This topic gives one example of dynamic show and hide. You might use this feature differently, depending on your business model.
This topic shows how to create the example described earlier. A business sells tee-shirts that can be personalized with the name and business name of the purchaser or that can be bought without personalization. The root product is a tee-shirt with attributes including the following: Personalize and Name. If the user selects the Personalize checkbox (which sets the Personalize attribute to Y), then an additional Siebel Product Configurator tab is displayed that allows the user to enter the customer's name and the business name.
This example assumes that you have defined the product and have defined the Siebel Product Configurator UI, including the tab used for personalization. The requirement is that you use the dynamic show and hide feature to hide the Name attribute when the Personalize checkbox is not selected (so the Personalize attribute is N).
To dynamically show and hide a Siebel Product Configurator control
On the Tee-Shirt product create the CfgUIStateModel UI property:
Navigate to the Administration - Product screen, Product Definitions view.
Lock the Tee-Shirt product.
Drill down on the Work Space version of the Tee-Shirt Product.
Navigate to the Properties view.
In the Properties list, add a new record and complete the necessary fields, as described in the following table.
Field Description Name
Enter CfgUIStateModel.
Value
Enter Y.
On the Tee-Shirt product, create the second UI property:
Enter Expr1.
Value
Enter CfgEval($.[Teeshirt]#1.xa[Personalize].xf[Value])='No'
On the Name attribute of the product, create the UI property:
Select the Name attribute.
Enter DynamicHide Expr1
Value
Enter Y
Release the root product.
