Roadmap for Creating Simple Products with Attributes
A simple product with attributes has features that the customer can choose but does not have components the customer can choose.
For example, a customer buying a t-shirt might be able to choose the shirt's color and its size. The shirt has two attributes, color and size. Each of these attributes has several possible values, such as white, gray, black, and S, M, L, XL.
To create a simple product with attributes, perform the following tasks:
  • Create scripts for the product with attributes. Optionally, you can enhance the behavior of Siebel Product Configurator by writing scripts in the Siebel eScript or the Siebel VB language. When the user selects certain attributes or does things like updating the shopping cart, you can use scripts to check the configuration, verify and adjust pricing, or forward information to other applications. See Siebel Product Configurator Scripts.
  • Create smart part numbers. If necessary, you can automatically generate a different part number for each combination of attributes that is available. For example, you can have part numbers for size S white shirt, size M white shirt, and so on. This allows you to pass the part numbers to back office applications used for filling orders. See Smart Part Numbers for Products with Attributes.
  • Testing Products with Attributes. After you have designed the product, user interface, and constraints, it is recommended that you test the product to make sure that it works with the products that are available now and in the future. See Testing Products and Using Workspace Projects.
  • Releasing Products with Attributes. After you have tested the product, you can release it to customers. See Releasing Products and Other Versioned Objects.
