Setting Up the Quick Edit Feature
To set up the quick edit feature, design the Siebel Product Configurator user interface in the usual way. Choose Base Theme with Quick Edit JS as the base theme for the interface. Associate this interface with the appropriate responsibility.
To set up the quick edit feature for the Siebel Product Configurator UI
Navigate to the Administration - Product screen, and then the Product Definitions view.
In the Products list, select the desired product and lock it if necessary.
In the Versions list, click the Workspace hyperlink.
Navigate to the User Interface view.
In the User Interface list, in the Base Theme field, select the template eCfgBaseAutoRepriceQuickEditJS.
