Verifying the Signals for Quick Edit
To enable the quick edit feature, use this procedure to verify that the following signal definitions are present:
PrepareEnableEngine
ReEnableiLogForQuickEdit
UpdateUIForQuickEdit
PrepareDisableEngine
To verify the signals for quick edit
Navigate to Administration - Order Management screen, then the Signals view.
In the Signals list, confirm that the PrepareEnableEngine signal was created.
In the Versions list, click on the latest version of the signal to drill down to the Actions list.
In the Actions list, confirm that the fields of the Action record have the values described in the following table.
Field Value Sequence
1
Service Type
Business Service
Service Name
Remote Complex Object Instance Service
Service Method
PrepareEnableEngine
Repeat Step 1 to Step 4 for the signals ReEnableiLogForQuickEdit, UpdateUIForQuickEdit, and PrepareDisableEngine.
Clear the cache.
