What’s New in Siebel Product Administration Guide, Siebel CRM 19.4 Update
The following information lists the changes in this revision of the documentation to support this release of the software.
| Topic | Description |
Updated this section to include the predefined UI property: EnableOraCfgEngine |
About the Siebel Constraint Engine |
Updated this section to include the different behaviors between the Siebel Constraint Engine and existing constraint technology. |
Process of Setting Up Siebel Constraint Engine |
Removed the section that described how to activate the Cfg Ora Engine Runtime Interaction Workflow. This workflow is no longer required. |
Setting Up the Siebel Constraint Engine System Preference |
Removed the system property: ConstraintEngineHost. This system property is no longer needed. |
Updated this section to include how the Siebel Constraint Engine defines resources as an integer type. |
