Reviewing the Installation Directories for Siebel Enterprise Components
This task is part of Verifying Installation for Siebel CRM.
After installing Siebel CRM, review the directory structure created by the installer for the Siebel Enterprise Components. For example, some or all of the directories described in the following table might now exist in the installation directory. Which directories are present in the installation directory depends on which Siebel CRM modules you installed, whether it was a new installation or an update or migration installation, whether you configured the application containers, and whether you completed configuration in Siebel Management Console.
cfgtoollogs, are also relevant to your Siebel Tools or Siebel Web
Client installation. However, several additional files and directories specific to the installed
client modules are also created in the top-level installation directory alongside of those for
the server modules. For additional directories that might have been created, see also Reviewing the Installation Directories for Siebel Tools and Reviewing the Installation Directories for the Siebel Web Client.| Directory | Description |
SIEBEL_ROOT |
SIEBEL_ROOT. Top-level directory for your Siebel CRM installation. The actual directory name is the directory where you installed the software. |
SIEBEL_ROOT\applicationcontainer_external |
applicationcontainer_external. Directory used by the application container for Siebel Application Interface. Several of these files are updated by the installer at the end of the installation process and can be examined to help make sure that installation was successful. |
SIEBEL_ROOT\applicationcontainer_external\conf |
conf. Contains the file server.xml, which can be examined for information such as the HTTPS port number of the installed application container. |
SIEBEL_ROOT\applicationcontainer_external\webapps |
webapps. Contains files for the Web applications supported by the application
container, including properties files. The subdirectory |
SIEBEL_ROOT\applicationcontainer_external\siebwebroot |
siebelwebroot. Contains the default HTML file (default.htm) and Web artifact
subdirectories, including |
SIEBEL_ROOT\applicationcontainer_internal |
applicationcontainer_internal. Directory used by the application container for Siebel Enterprise components (Siebel Server, Siebel Gateway, and so on). Several of these files are updated by the installer at the end of the installation process and can be examined to help make sure that installation was successful. |
SIEBEL_ROOT\applicationcontainer_internal\conf |
SIEBEL_ROOT\applicationcontainer_internal\webapps |
SIEBEL_ROOT\applicationinterface |
applicationinterface. Directory used by Siebel Application Interface. |
SIEBEL_ROOT\cfgtoollogs |
cfgtoollogs. Directory used for installation log files. |
SIEBEL_ROOT\config |
config. Directory used for configuraiton files. |
SIEBEL_ROOT\dbsrvr |
dbsrvr. Directory used by Database Configuration Utilities. |
SIEBEL_ROOT\diagnostics |
diagnostics. |
SIEBEL_ROOT\eaiconn |
eaiconn. Directory used by EAI connector. |
SIEBEL_ROOT\gtwysrvr |
gtwysrvr. Directory used by Siebel Gateway. |
SIEBEL_ROOT\inventory |
inventory. Directory used for the installation inventory. |
SIEBEL_ROOT\jre |
jre. Directory used by the Java Runtime Environment. |
SIEBEL_ROOT\manifest |
manifest. Directory used for manifest files. |
SIEBEL_ROOT\oui |
oui. Directory used by Oracle Universal Installer software. |
SIEBEL_ROOT\siebsrvr |
siebsrvr. Directory used by Siebel Server. |
